hahahaqing
Weird JMP displacement
I am new to JMP. Some of my JMP windows has this weird display. The text font is very big. This problem appeared suddenly (It used to be fine). I don't know what I changed. I've tried to restart and reinstall the JMP several times but the problem isn't solved. Any ideas would be really appreciated!
Jeff_Perkinson
Re: Weird JMP displacement
Have you looked at File->Preferences->Fonts to see if there are odd settings there?
-Jeff
Thierry_S
A quick fix: hold "CTRL" "SHIFT" "-" to decrease the overall font size across all display in JMP
Thierry R. Sornasse
hahahaqing
Hi Thierry,
Thanks for your response so much! I tried but it decreases the overall font size.  But in my JMP, some sections show regular font size, some have the weird big fond size. For example, in the graph builder window below, the "Points" section has the regular font size but other sections have the weird big font size.
Also, my data table shown below has the regular font size... How could I just adjust the font size of the weird sections?
Jeff_Perkinson
-Jeff
hahahaqing
Hi Jeff,
I really appreciate it! Yes the settings were changed somehow. Now it's fixed! Thank you for your help so much!
