I did this and it works. Probably a lot better ways out there though. Makes the columns continuous only while the plot window is open.
Current Data Table():SiteY << Set Modeling Type( "Continuous" );
Current Data Table():SiteX << Set Modeling Type( "Continuous" );
Map = Graph Builder(
Size( 1526, 846 ),
Variables( X( :SiteX ), Y( :SiteY ), Group X( :NOTCH ) ),
Elements( Heatmap( X, Y, Legend( 2 ) ) ),
Dispatch(
"SiteX",
ScaleBox,
{Min( -2.60356855144495 ), Max( 4.92191130833973 ), Inc( 1 ),
Minor Ticks( 0 )}
Dispatch(
"SiteY",
ScaleBox,
{Min( -1.80170994183197 ), Max( 5.23594729081798 ), Inc( 1 ),
Minor Ticks( 0 )}
Dispatch(
"Graph Builder",
FrameBox,
{Add Graphics Script(
2,
Description( "" ),
Transparency( 0.5 );
Fill Color( "Gray" );
Oval( -0.1, 1.2, 6.3, 7.4, 1 );
Pen Size( 2 );
Line( [-0.1, 0.35, -0.1], [4.25 4.5 4.75] );
Pen Color( "Black" );
Pen Size( 2 );
Pen Size( 1 );
Line Style( "Dotted" );
Oval( 0, 1.3, 6.2, 7.3 );
Transparency( 1 );
Fill Color( "White" );
Polygon( [-0.1, 0.35, -0.1], [4.25 4.5 4.75] );
Line Style( "Solid" );
Fill Color( 1 );
Rect( 2, 6, 4, 7 );
Rect( 1, 5, 5, 6 );
Rect( 1, 4, 5, 5 );
Rect( 1, 3, 5, 4 );
Rect( 2, 2, 5, 3 );
Rect( 1, 3, 2, 6 );
Rect( 2, 2, 3, 7 );
Rect( 3, 2, 4, 7 );
Rect( 4, 2, 5, 6 );
Dispatch(
"Graph Builder",
FrameBox( 2 ),
2,
Description( "" ),
Oval( 1.1, 0.9, 7.2, 7.1, 1 );
Pen Size( 2 );
Line( [4 4.25 4.5], [7.1, 6.85, 7.1] );
Pen Size( 2 );
Oval( 1.1, 0.9, 7.2, 7.1 );
Pen Size( 1 );
Oval( 1.2, 1, 7.1, 7 );
Transparency( 1 );
Polygon( [4 4.25 4.5], [7.1, 6.85, 7.1] );
Fill Color( 1 );
Rect( 3, 5, 6, 6 );
Rect( 2, 4, 7, 5 );
Rect( 2, 3, 7, 4 );
Rect( 2, 2, 6, 3 );
Rect( 6, 3, 7, 5 );
Rect( 5, 2, 6, 6 );
Rect( 4, 2, 5, 6 );
Rect( 3, 2, 4, 5 );
Rect( 2, 2, 3, 5 );
Map << On Close(
Current Data Table():SiteY << Set Modeling Type( "Ordinal" );
Current Data Table():SiteX << Set Modeling Type( "Ordinal" ););
Slán
SpannerHead
