SpannerHead
Wafer Maps
I have been drawing wafer maps in Graph Builder using Customize Graph.  One issue I have is that the custom outline I have remains static in the frame, whereas the die can move depending on where they are populated.
For example, if I only test a few die, their location appears to relocate to the bottom and left relatively to the drawing.
Aside from adding bogus data to occupy the previous extremities, is there a way to have the relationship remain fixed?  The code contained in the Customize Graph Script is as follows.
Transparency( 0.5 );
Fill Color( "Gray" );
Oval( -1, -1, 7, 7, 1 );
Pen Size( 2 );
Line( [-1, -0.855, -1], [2.75 3 3.25] );
Pen Color( "Black" );
Pen Size( 2 );
Oval( -1, -1, 7, 7 );
Pen Size( 1 );
Line Style( "Dotted" );
Oval( -0.9, -0.9, 6.9, 6.9 );
Transparency( 1 );
Fill Color( "White" );
Polygon( [-1, -0.855, -1], [2.75 3 3.25] );
Line Style( "Solid" );
Fill Color( 1 );
Rect( 1.5, -0.5, 4.5, 0.5 );
Rect( 0.5, 0.5, 5.5, 1.5 );
Rect( 0.5, 1.5, 5.5, 2.5 );
Rect( -0.5, 2.5, 6.5, 3.5 );
Rect( 0.5, 3.5, 5.5, 4.5 );
Rect( 0.5, 4.5, 5.5, 5.5 );
Rect( 1.5, 5.5, 4.5, 6.5 );
Rect( -0.5, 2.5, 0.5, 3.5 );
Rect( 0.5, 0.5, 1.5, 5.5 );
Rect( 1.5, -0.5, 2.5, 6.5 );
Rect( 2.5, -0.5, 3.5, 6.5 );
Rect( 3.5, -0.5, 4.5, 6.5 );
Rect( 4.5, 0.5, 5.5, 5.5 );
Rect( 5.5, 2.5, 4.5, 3.5 );
Slán
SpannerHead
SpannerHead
Re: Wafer Maps
I did this and it works.  Probably a lot better ways out there though.  Makes the columns continuous only while the plot window is open.
Current Data Table():SiteY << Set Modeling Type( "Continuous" );
Current Data Table():SiteX << Set Modeling Type( "Continuous" );
Map = Graph Builder(
	Size( 1526, 846 ),
	Variables( X( :SiteX ), Y( :SiteY ), Group X( :NOTCH ) ),
	Elements( Heatmap( X, Y, Legend( 2 ) ) ),
		Dispatch(
			"SiteX",
			ScaleBox,
			{Min( -2.60356855144495 ), Max( 4.92191130833973 ), Inc( 1 ),
			Minor Ticks( 0 )}
		Dispatch(
			"SiteY",
			ScaleBox,
			{Min( -1.80170994183197 ), Max( 5.23594729081798 ), Inc( 1 ),
			Minor Ticks( 0 )}
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Add Graphics Script(
				2,
				Description( "" ),
				Oval( -0.1, 1.2, 6.3, 7.4, 1 );
				Pen Size( 2 );
				Line( [-0.1, 0.35, -0.1], [4.25 4.5 4.75] );
				Pen Size( 2 );
				Pen Size( 1 );
				Oval( 0, 1.3, 6.2, 7.3 );
				Transparency( 1 );
				Polygon( [-0.1, 0.35, -0.1], [4.25 4.5 4.75] );
				Fill Color( 1 );
				Rect( 2, 6, 4, 7 );
				Rect( 1, 5, 5, 6 );
				Rect( 1, 4, 5, 5 );
				Rect( 1, 3, 5, 4 );
				Rect( 2, 2, 5, 3 );
				Rect( 1, 3, 2, 6 );
				Rect( 2, 2, 3, 7 );
				Rect( 3, 2, 4, 7 );
				Rect( 4, 2, 5, 6 );
		Dispatch(
			"Graph Builder",
			FrameBox( 2 ),
				2,
				Description( "" ),
				Oval( 1.1, 0.9, 7.2, 7.1, 1 );
				Pen Size( 2 );
				Line( [4 4.25 4.5], [7.1, 6.85, 7.1] );
				Pen Size( 2 );
				Oval( 1.1, 0.9, 7.2, 7.1 );
				Pen Size( 1 );
				Oval( 1.2, 1, 7.1, 7 );
				Transparency( 1 );
				Polygon( [4 4.25 4.5], [7.1, 6.85, 7.1] );
				Fill Color( 1 );
				Rect( 3, 5, 6, 6 );
				Rect( 2, 4, 7, 5 );
				Rect( 2, 3, 7, 4 );
				Rect( 2, 2, 6, 3 );
				Rect( 6, 3, 7, 5 );
				Rect( 5, 2, 6, 6 );
				Rect( 4, 2, 5, 6 );
				Rect( 3, 2, 4, 5 );
				Rect( 2, 2, 3, 5 );
Map << On Close(
Current Data Table():SiteY << Set Modeling Type( "Ordinal" );
Current Data Table():SiteX << Set Modeling Type( "Ordinal" ););
Slán
SpannerHead
15 REPLIES 15
SpannerHead
Re: Wafer Maps
I should probably point out that I treat the x and y coordinates as ordinal variables.  Changing that seems to alter the frame of reference.  I guess my question is, can I keep those as ordinal and still achieve alignment consistency?
Slán
SpannerHead
Re: Wafer Maps
Have you considered using map files? You can check the values which get assigned to each point from axis settings
I think if you are using Ordinal modelling types, you might have to add those "missing" points to your data. Usually this is quite easy to do with a join if you have a mapping table. If I remember correctly there will be a column property in JMP19 which should make this easier.
SpannerHead
Re: Wafer Maps
	Size( 1526, 846 ),
		Dispatch(
			"SiteX",
			ScaleBox,
			Minor Ticks( 0 )}
		Dispatch(
			"SiteY",
			ScaleBox,
			Minor Ticks( 0 )}
		Dispatch(
			"Graph Builder",
			FrameBox,
				2,
				Description( "" ),
				Pen Size( 2 );
				Pen Size( 2 );
				Pen Size( 1 );
				Transparency( 1 );
				Fill Color( 1 );
				Rect( 2, 6, 4, 7 );
				Rect( 1, 5, 5, 6 );
				Rect( 1, 4, 5, 5 );
				Rect( 1, 3, 5, 4 );
				Rect( 2, 2, 5, 3 );
				Rect( 1, 3, 2, 6 );
				Rect( 2, 2, 3, 7 );
				Rect( 3, 2, 4, 7 );
				Rect( 4, 2, 5, 6 );
		Dispatch(
			"Graph Builder",
			FrameBox( 2 ),
				2,
				Description( "" ),
				Pen Size( 2 );
				Pen Size( 2 );
				Pen Size( 1 );
				Transparency( 1 );
				Fill Color( 1 );
				Rect( 3, 5, 6, 6 );
				Rect( 2, 4, 7, 5 );
				Rect( 2, 3, 7, 4 );
				Rect( 2, 2, 6, 3 );
				Rect( 6, 3, 7, 5 );
				Rect( 5, 2, 6, 6 );
				Rect( 4, 2, 5, 6 );
				Rect( 3, 2, 4, 5 );
				Rect( 2, 2, 3, 5 );
Map << On Close(
Slán
SpannerHead
Re: Wafer Maps
I think you could also use Transform Columns to create those continuous columns
dt = open("$SAMPLE_DATA/Big Class.jmp");
dt << Select Where(:age == 14) << Hide and Exclude(1) << Clear Select;
gb = dt << Graph Builder(
	Transform Column("Transform[age]", Formula(:age)),
	Size(525, 454),
	Show Control Panel(0),
	Variables(X(:"Transform[age]"n), Y(:height)),
	Elements(Points(X, Y, Legend(13)))
Write();
SpannerHead
Re: Wafer Maps
The problem however with continuous data is the way it references the die.  The actual die number on X is to the left of the die rather than the middle.  On Y the number is to the bottom.  Creates a disclaimer requirement for every communication.
Slán
SpannerHead
Level XIII
Re: Wafer Maps
very common problem.
A  setting to shift the axis labels( offset +0.5) could help many users :)
Re: Wafer Maps
Hi, @SpannerHead
The trick to making this work consistently is to use map shape files. This lets you assign colors based on the XY Die coordinates and makes sure they consistently show up in the same place.
The Semiconductor Toolkit Add-in (formerly here ) will be arriving in the JMP Marketplace in the fall.  It's designed specifically for this kind of data and visualization and will make those shape files for you.  Here's a little preview:
Best,
M
Luis_HC
Re: Wafer Maps
Will the new STK provide a workaround for the geodesic axes as-default?
Re: Wafer Maps
@Luis_HC - Yep - though that's nothing special to the STK - just a feature of the shape files.  Unless there is a coordinate system in the shape file that needs geodesic axes, it shouldn't use them.
