hupin
Value Ordering
Hi, is there a quick way to change the label ordering ?
usually I go to "col properties"--> "value ordering" to change the order
I'm look for some way able to right click from the graph and directly change the label order, if possible
because other software I'm using is able to do this, very convenient
thanks for solutions
Jeff_Perkinson
Re: Value Ordering
Unfortunately there's no way to set value ordering except as you're currently doing with Column Properties.
I'll pass along the suggestion to our development team though.
Thanks!
-Jeff
-Jeff
hupin
Re: Value Ordering
thank you
