Konstantinl
Using externally calculated st.dev. in X by Y
Hi everyone,
i occasionally get datasets, where there is no raw data available, just the mean, st.dev. and number of replicates. Is there a way to use this available data to run a t-test, for instance? A quick platform launch is included to show what I want to do.
I was thinking, that maybe constructing a simulated distribution (let's assume it's normal) with the given parameters and counts could be the way to go, but I I'm not sure how to do that. Does anyone have an idea? A scripted solution would be good, i could adapt that.
Have a great day!
Kanstantsin
Re: Using externally calculated st.dev. in X by Y
You might also be able to use this solution.
You would have to run very many bootstrap samples to approach inference by resampling.
Georg
You can use --> Sample Index --> Teaching Scripts for a t-test with summary statistics:
But may be not appropriate for many rows.
Georg
Konstantinl
Hi Georg, thanks for this! Didn't know this option existed! Doesn't scale too greatly unfortunately.
The solution that Mark gave is what I was looking for! And, yeah, that's not a dataset with high effects...
Konstantinl
Hi Mark,
thanks a lot! yes, this worked rather nicely, and so did the concatenation for categories that Ron mentions in his reply.
Georg
I would probably use this graph to understand the data, mean on y and stddev as interval:
Resampling can be done of course, but will not lead to a good assessment with small differences.
Georg
