tking
Send Mail Error/Fault
I have a script that monitors process parameters, scrap product and sends email messages to various users based on query results. For the most part there is no issue. Occassionally though, when checking JMP to ensure that there are no issues, I see a Send Mail Fault in a dialog box with an OK button in JMP (using JMP 8, if that matters). I click OK and JMP continues on without a problem. I do not understand what causes this fault. The same Mail() statement will work fine most of the time. Next time it happens, I will look through the log to see if anything posts there. Anyone?
tking
Re: Send Mail Error/Fault
The actual text of the fault is "Send mail failed." There was nothing listed in the log.
