maze
Can I parse data from .txt file using JSL?
Re: Can I parse data from .txt file using JSL?
Yes.  If appropriate you can read the file into a JMP data table and process it that way, or you can read it using
    Load Text File
and read it into a string and process the string.
If you can provide more details, I am sure the Community will be able to provide more detailed help.
