It is easier to test if you just ignore For Each (for now). Start with something like this
// dt = Open("$DOWNLOADS/AAA.jmp");
// dt = Current Data Table();
dt = New Table("AAA(1)",
	Add Rows(12),
	Compress File When Saved(1),
	New Column("obj", Character(16), "Nominal", Set Values({"A", "A", "A", "A", "A", "A", "A", "B", "B", "B", "C", "C"})),
	New Column("T",	Character(4), "Ordinal", Set Values({"3052", "3061", "3082", "3940", "4012", "5010", "2890", "4060", "3061", "3081", "5010", "3061"})),
	New Column("OPE", Numeric, "Continuous", Format("Best", 12), Set Values([12, 20, 32, 44, 56, 125, 210, 54, 60, 80, 45, 50])),
	New Column("X__3", Character(4), "Nominal", Set Values({"rien", "rien", "incl", "ret", "ret", "rien", "incl", "incl", "ret", "incl", "ret", "rien"})),
	New Column("SOMME DEFAUT", Numeric, "Continuous", Format("Best", 12), Set Values([0, 0, 1, 2, 1, 0, 2, 1, 2, 1, 1, 0])),
	New Column("op", Character(12), "Nominal", Set Values({"40", "32", "55", "212", "510", "180", "2100", "2240", "2100", "500", "", ""})),
	New Column("correct", Character, "Nominal", Set Values({"", "ko - 55 / ko - 212 / ko - 510 / ko - 2100", "", "", "", "", "", "", "ko - 500", "", "", "."}))
dt << New Column("bilan", Character, Nominal);
Summarize(dt, unique_objects = by(:obj));
m_obs = dt[0, "obj"];
unique_object = unique_objects[2];
object_rows = Loc(m_obs, unique_object);
input_loc = Loc(dt[object_rows, "T"], "3061"); // location of 3061 for unique_object
show(input_loc); // index within object_rows
show(object_rows[input_loc]); // real row number
opes = dt[object_rows, "OPE"]; // all OPE values for unique_object
valid_ope_idx = Loc(...//
