For loop
I would like to generate all these plots in one tab, rather than generating 50 different pages, can anyone help ? thank you
dt = Current Data Table();
For( i = 1, i <= 50, i++,
	dt << Bivariate(
		Y( Column( dt, "u" || Char( i ) ) ),
		X( Column( dt, "oven.T" ) ),
		Fit Line( {Line Color( {212, 73, 88} )} )
Re: For loop
Here is one way to do what you want
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
colListY = {};
For( i = 1, i <= 10, i++,
	Insert Into( colListY, "NPN" || Char( i ) )
dt << Bivariate(
	Y( Eval( colListY ) ),
	X( Column( dt, "PNP1" ) ),
Here is another way
dt =
colListY = {};
New Window( "My Output",
	H List Box(
			dt << Bivariate(
				Y( Column( dt, colListY[i] ) ),
Re: For loop
Thank you!
