fizzy
Edit Effect Summary and Interaction Profiles
Hello all,
I have two trivial questions.
  • Is there an option to add two blue lines to the effect summary plot? I want there to be a line at p=0,05 and p=0,001 beside the one at p=0,01. Like this:
  • Is there a way to copy the interaction profiles to the graph builder?  I don't like the format and want to change things, like the legend or the order of the x Labels
Thanks in advance!
BHarris
Re: Edit Effect Summary and Interaction Profiles
Re. the Graph Builder question, you can change the ordering of the x-labels using the "Value Order" property of columns, i.e. right-click the column header, select "Column Properties" -> "Value Order".  Or you can reorder them by some other variable by right clicking the axis labels and selecting "Order By"...
