Script to find and replace
KRT
KRT
I use a GCMS program which adds "saturated (####)" when a peak area count is saturated.  After I export these results from excel into a JMP data table, I would like to run a script which finds these occurrences and removes the "saturated ()" but leaves the number in numeric, continuous 12,0 format.
Re: Script to find and replace
Try this on your Area column
// Loop across all character columns and find those who have the pattern (###)
// and if found, then convert all columns
For( k = 1, k <= N Rows( dt ), k++,
	If( Contains( :Area[k], "(" ),
		:Area[k] = Word( 2, :Area[k], "()" )
:Area << data type( numeric ) << modeling type( continuous ) << Format( "Fixed Dec", 12, 0 );
Interactively, it is quite easy to use the Find capability to do a global replace of "(" and ")".  Then, using Standardize Attributes you can select all of the columns in question, and change them to numeric, continuous, format(Fixed Dec, 12,0)
Find is available at
     Edit=>Search=>Find
Standardize Attributes is available under the red triangle in the Columns Panel on the left side if the data table.
Here is a little script that will also do the trick, but with a large data table, it might be slow
// Get all character columns
colList = dt << get column names( character, string );
For( I = 3, i <= N Items( colList ), i++,
	If( Left( char(Column( dt, colList[i] )[1]), 1 ) == "(" & Right( char(Column( dt, colList[i] )[1]), 1 ) == ")",
			If( Left( (Column( dt, colLIst[i] )[k]), 1 ) == "(",
				Column( dt, colList[i] )[k] = Substr( Column( dt, colList[i] )[k] ,
				2)
			If( Right( (Column( dt, colList[i] )[k]), 1 ) == ")",
				Column( dt, colList[i] )[k] = Word( 1, Column( dt, colList[i] )[k], ")" )
		// Convert to numeric, etc.
		Column( dt, colList[i] ) << data type( numeric ) << modeling type( continuous ) <<
KRT
KRT
Thank you for the script, but it appears I was not specific enough.  Writing script is very new for me and I assumed the length of the number did not matter.  I am guessing that was wrong.  I played around with the script but could not get it to turn "saturated( 635403558 )" into 635403558.  I appreciate your help.
The script expects the "(" to be ithe first character, and the ")" to be the last character.  Is it possible that blank characters are at the beginning or end?
try this version of the script and see if it helps
For( I = 1, i <= N Items( colList ), i++,
	If( Left( Trim( Char( Column( dt, colList[i] )[1] ) ), 1 ) == "(" & Right( Trim( Char( Column( dt, colList[i] )[1] ) ), 1 ) == ")",
			If( Left( (Trim( Column( dt, colLIst[i] ) )[k]), 1 ) == "(",
				Column( dt, colList[i] )[k] = Substr( Trim( Column( dt, colList[i] )[k] ), 2 )
			If( Right( Trim( Column( dt, colList[i] )[k] ), 1 ) == ")",
		Column( dt, colList[i] ) << data type( numeric ) << modeling type( continuous ) << Format( "Fixed Dec", 12, 0 );
ian_jmp
Level X
If I understand correctly, this might be a chance to use JMP's pattern matching (thanks to @Craige_Hales
NamesDefaultToHere(1);
// Define a function
removeSaturated =
Function({inStr}, {Default Local},
	// A pattern that will match a span of digits, with or without a leading '-'
	digits = (""|"-") + patSpan("0123456789");
	// Put the match into 'found' (might be identical to 'inStr')
	patMatch(inStr, digits >? found);
	// Return 'found' as a number
	Num(found);
// Try it out
Print(removeSaturated("saturated( 635403558 )"));
Print(removeSaturated("saturated(635403558)"));
Print(removeSaturated("635403558"));
Print(removeSaturated("635403"));
Print(removeSaturated("-635403"));
Print(removeSaturated("saturated(  -635403  )"));
KRT
KRT
Sadly nothing happened when I ran the script.  I included a screen shot of my data along with the column attributes, if that helps.  Thanks again!
ian_jmp
Level X
The code I gave above just writes to the JMP Log. Looks like @txnelson has already told you how to handle your 'Area' column. If you wanted to, you could use a combination of the pattern matching code and his JSL.
With all these things it comes down to what you can safely assume about the regularity of the input. Whilst the pattern matching approach is (slightly) more general (and could easily be made more so), in your case it may not matter.
No recommendations found
