MathStatChem
Technical Details of Variable Importance Calculations
I am looking for more technical details (beyond what is stated in the JMP documentation) about how Variable Importance is calculated (available under the Prediction Profiler options).
I have read the two reference papers listed in the documentation (Sobol (2001) and Saltelli (2002)).  I think I get the general idea, but I what I want to know is more of the gritty details on how the monte carlo simulation is done (just for independent uniform inputs)
  • how is the monte carlo simulation setup and executed?  From what I see in the papers, you do different kinds of random input combinations based on subsets of the input variables ?  This is the part I am most confused about and that is least explained in the documentation.
  • how many monte carlo runs are performed.  It appears to be based on the size of the data set, but it is unclear and not described in the documentation.
  • How are the Main Effect and Total Effect metrics for variable importance calculated from the simulation results.
This is more than just "wanting to know the math".  What I need to do is to compare this approach to other variable importance/impact assessments, which is becoming more and more popular in pharma QbD approaches to determine process parameter criticality.
Kevin_Anderson
Re: Technical Details of Variable Importance Calculations
Hi, MathStatChem!
This might not help you very much, since I don't know much about the nuts and bolts underneath the hood either (and I'm excited to hear from someone who does know!), but there's a JSL Utility function called Sobol Quasi Random Sequence(nDim, nRow), that's described as generating "a sequence of space-filling quasi random numbers using the Sobol sequence in up to 4000 dimensions".  I always assumed this supports the simulation in "The Sobolizer", what some insiders called the Variable Importance system.
There's a lot floating around in the internets regarding Sensitivity Analysis that I'm sure you've researched too.  'Sorry to be so unhelpful.
Good luck!
Kevin
