I am trying to script a series of Variability Charts in a single Window, which I could save to a JRN or pptx later.
Each chart is intended to display the values (in Y) of different parameters (e.g. Height, Weight, Length) with different combination of independent X axis {due to this reason, I could not script it as By( :Parameter_Class ) } in a single Variability Chart platform.
Problem: Displayed output from a manually graphed chart would have the parameter name nicely printed in the Outline Box but what's obtained from the script below would look out-of-place and not nicely formatted. Any way it could be scripted that meets the desired format?
Desired:
Obtained:
New Window( "Variability Chart for Parameters",
Variability Chart(
Y( :Value ),
X( :colA, :colB, :colC, :colD ),
Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
Std Dev Chart( 0 ),
Where( :Parameter_Class == "Height" )
Variability Chart(
Y( :Value ),
X( :colA, :colB, :colC, :colD, :colE ),
Std Dev Chart( 0 ),
Where( :Parameter_Class == "Weight" )
Variability Chart(
Y( :Value ),
X( :colC, :colE ),
Std Dev Chart( 0 ),
Where( :Parameter_Class == "Length" )
