AlexS
Save completed message
Hello
I have a script when saves all data tables to a folder and then closes all open data tables but it takes a little while. I would like a message to inform the user when all the tables have finished saving.
Could someone provide me with a basic script of how that would work?
Many thanks
Alex is the name, Power BI/ SQL /JMP is my game
ts2
ts2
Re: Save completed message
Here are a couple methods. If you prefer a modal popup you will need to use the bottom method.
Caption( "\!n\!nSave Complete\!n\!n" );
New Window( "Save Complete", <<Modal, <<Show Menu( 0 ), <<Show Toolbars( 0 ), Text Box( "\!n\!nSave Complete\!n\!n" ) );
ts2
ts2
AlexS
Thank you, exactly what i needed.
