BookmarkSubscribeRSS Feed
hsrcadmin
Oct 19, 2017
SAS structural Equation Modeling for JMP Add-In
can any one help me if the SAS structural Equation Modeling for JMP Add-In is still available?
i searched about it and it says that it is no longer available: http://www.jmp.com/support/notes/51/749.html
it says that the latest version work with JMP 10.0.2 only
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
Re: SAS structural Equation Modeling for JMP Add-In
As the support note indicates, the SEM add-in is no longer available.
-Jeff
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
-Jeff
hsrcadmin
Oct 19, 2017
do you have any idea if they replace it with another one?
or did they add it as a built in function in the JMP software ?
Jeff_Perkinson
Community Manager
Jun 23, 2011
It is not available at this time and there is no built-in function.
It is under consideration for a future release of JMP.
-Jeff
