BookmarkSubscribeRSS Feed
Running all table scripts with one command
Hi Guys,
I have several data table files (> 100) and each file has a table script embedded in it. When I open the files, I would like to run all the scripts associated with each data table. Is there a command that will do this?
Thanks.
chungwei
Re: Running all table scripts with one command
Can you change the name of the script you want to run to "OnOpen" ?
