BookmarkSubscribeRSS Feed
daniel_harding
Community Trekker
Rows from table as part of formula for columns in a different table
Hi all,
I am attempting to make a new data table with columns based on a formula using row values from a previous table, each row used at a time like this:
dttest << New Column( "Test 1",
  formula(random normal( (slope* Row1 of first table)  + meantime, assay ))
  dttest << New Column( "Test 2",
  formula(random normal ( (slope * Row2 of first table) + meantime, assay))
  dttest << New Column( "Test 3",
  formula(random normal ( (slope * Row3 of first table) + meantime, assay))
thanks for any help or tips in the right direction
wiebepo
Community Trekker
Re: Rows from table as part of formula for columns in a different table
Consider this approach. It will create the column values as desired, but will not be dynamic. If the first table is updated, it will not update the values in dttest. If this is not a requirement, then set each value can be a flexible command to introduce values and references from other tables or from inside variables.
  <<seteachvalue(random normal( (slope* column(first table global, column name or number from first table)[1])  + meantime, assay ))
<<seteachvalue(random normal ( (slope * column(first table global, column name or number from first table)[2]) + meantime, assay))
  <<seteachvalue(random normal ( (slope *column(first table global, column name or number from first table)[3] ) + meantime, assay))
wiebepo
Community Trekker
daniel_harding
Community Trekker
This works well, thanks so much
