Hi Jim,
Great to know that both approaches are possible to do in JSL.
Would it be possible to alter the code to also have Y( :"Test value"n ) to go through all the continuous columns?
// Determine the levels in the ID column
summarize( sd, ByGroups = By( :ID ) );
// Loop across each level of ID
For Each( {BG, group}, ByGroups,
Fm = Fit Model(
Y( :"Test value"n ),
Effects( :Person ),
Random Effects( :Day[:Person] ),
NoBounds( 0 ),
Method( "REML" ),
Emphasis( "Effect Leverage" ),
Run(
:"Test value"n << {Summary of Fit( 1 ), Analysis of Variance( 0 ),
Parameter Estimates( 1 ), Scaled Estimates( 0 ), Plot Actual by Predicted( 1 ),
Plot Regression( 0 ), Plot Residual by Predicted( 1 ),
Plot Studentized Residuals( 0 ), Plot Effect Leverage( 1 ),
Plot Residual by Normal Quantiles( 0 ), {:Person << {LSMeans Student's t( 0.05 )}}}
Where( :ID == ByGroups[group] ),
Dispatch( {"Test value ID=A1"}, "Whole Model", OutlineBox, {Close( 1 )} ),
Dispatch(
{"Test value ID=A1", "Person"},
"Leverage Plot",
OutlineBox,
{Close( 1 )}
// Save the pointer to the results in the Fitmod list
Insert Into( Fitmod, Fm );
);I have looked at many other loops and tried to alter it to the following:
sd = Open( "test_table_002.jmp" );
Data Table( "test_table_002" );
Fitmod = {};
colList = sd << Get Column Names( Continuous, String );
For Each( i = 1, i <= Nitems( colList ), i++,
Fm = Fit Model(
Y( colList ),
Effects( :Person ),
NoBounds( 0 ),
Method( "REML" ),
Run(
colList << {Summary of Fit( 1 ), Analysis of Variance( 0 ),
Dispatch(
"Leverage Plot",
OutlineBox,
{Close( 1 )}
);However, I get an error code that I do not fully understand.
I have attached a test table and I double checked that I attached the correct one.
Best regards,
Julie
Best regards,
Julie
