Thank you everyone for your suggestions.
I need most of the (long) nominal character columns for grouping. Removing a few ordinal character columns had a negligible affect on performance.
Yes, every machine is different (and running different background processes). Based on my M's (machine, material/data, and method), JMP gets shut down (or freezes) when the machine approaches 65% RAM usage; this was using a data table of 200,000 rows (about 20,000 KB). At this point, Windows Task Manager showed JMP memory usage at 1,343,424 KB.
Note that I was using these steps: (1) open JMP, (2) open DT & color rows, (3) run CChart, (4) create Journal, and (5) save as PDF.
Any help with interpreting data table file sizes (converting from KB to GB) for JMP memory management would be appreciated. Thanks!.
![10076_RAM_Usage.png 10076_RAM_Usage.png](https://community.jmp.com/t5/image/serverpage/image-id/2227iF23E6E3BE9A92797/image-size/medium?v=v2&px=400)
