Yass
Plotting a Distribution Tracking Chart Over a Defined Date Range
Hi everyone,
I hope you're all doing well ! I have a question and would really appreciate your help.
I've been working on a function to create a NOK tracking chart that shows the NOK percentages over a specific date range. Here's a quick rundown of what i want my function to do :
- I get the start and end dates for the current month.
- Next i creat new table to store the NOK percentages for each date and It goes through each day from the start of the month to today.
- Then it inserts the date and the corresponding NOK percentages into the new table.
- Finally, it creates a line graph showing the NOK percentages over the date range.
I've got the function mostly working, but I'm running into a bit of trouble.
TOP5:get_dates = Function({},
    today_date = Format(Today(), "yyyy-mm-dd");
    start_of_month = Format(Date Increment(Today(), "Month", 0, "Start"), "yyyy-mm-dd");
    evallist({start_of_month, today_date});
TOP5:calculate_nok_percentages = Function({dt},
    {start_of_month, today_date} = TOP5:get_dates();
    dt_top5 = dt << Summary(
        Group(:Date, :Nom de fichier, :Ref Produit, :ProductName, :Baie, :ICT_FCT, :Result, :Reason Error, :CodeError),
        Freq("Aucun(e)"),
        Weight("Aucun(e)"),
        invisible
    nameFilesNok = Associative Array(Column(dt_top5, "Nom de fichier") << Get Values) << Get Keys;
    total_nb_total_ict = 0;
    total_nb_total_fct = 0;
    total_nb_nok_ict = 0;
    total_nb_nok_fct = 0;
    For(k = 1, k <= N Items(nameFilesNok), k++,
        FileRows = dt_top5 << get rows where(
            :File Name == nameFilesNok[k] & Num(Char(:Date)) >= Num(start_of_month) & Num(Char(:Date)) <= Num(today_date) & Contains(:File Name, "GOLDEN") == 0
        nb_total_ict = 0;
        nb_total_fct = 0;
        nb_nok_ict = 0;
        nb_nok_fct = 0;
        total_rows = N Items(FileRows);
        For(j = 1, j <= total_rows, j++,
            If(dt_top5:ICT_FCT[FileRows[j]] == "ICT",
                nb_total_ict = nb_total_ict + dt_top5:Nb. de lignes[FileRows[j]];
                If(dt_top5:Result[FileRows[j]] == "NOK",
                    nb_nok_ict = nb_nok_ict + dt_top5:Nb. de lignes[FileRows[j]]
            , dt_top5:ICT_FCT[FileRows[j]] == "FCT",
                nb_total_fct = nb_total_fct + dt_top5:Nb. de lignes[FileRows[j]];
                    nb_nok_fct = nb_nok_fct + dt_top5:Nb. de lignes[FileRows[j]]
        total_nb_total_ict += nb_total_ict;
        total_nb_total_fct += nb_total_fct;
        total_nb_nok_ict += nb_nok_ict;
        total_nb_nok_fct += nb_nok_fct;
    percent_nok_ict = (total_nb_nok_ict / total_nb_total_ict) * 100;
    percent_nok_fct = (total_nb_nok_fct / total_nb_total_fct) * 100;
    Eval List({percent_nok_ict, percent_nok_fct});
TOP5:create_nok_tracking_chart = Function({dt},
    dt_nok = New Table("NOK Percentages",
        Add Rows(0),
        New Column("Date", Character),
        New Column("Percent NOK ICT", Numeric),
        New Column("Percent NOK FCT", Numeric)
    For(i = Num(start_of_month), i <= Num(today_date), i++,
        // Correct date formatting
        today_str = Format(Date(i), "yyyy-mm-dd");
        Eval List({start_of_month, today_date}) = Eval List({today_str, today_str});
        result = TOP5:calculate_nok_percentages(dt);
        Insert Into(dt_nok,
            today_str,
            result[1],
            result[2]
    Graph Builder(
        Size( 700, 500 ),
        Variables( X( :Date ), Y( :Percent NOK ICT ), Y( :Percent NOK FCT ) ),
        Elements(
            Line(
                X,
                Y( 1 ),
                Legend( 6 ),
                Line Color( "Red" )
            Line(
                X,
                Y( 2 ),
                Legend( 8 ),
                Line Color( "Blue" )
        Legend Position( "Top" )
i did get this error message :
Unresolved name: Date JSL when accessing or evaluating "Date JSL". Date JSL( i ) /*###*/
Could anyone provide some guidance or tips on how to improve this ?
Thanks a lot!
19 REPLIES 19
Yass
Re: Plotting a Distribution Tracking Chart Over a Defined Date Range
The argument must be numeric at line 1 when accessing or evaluating 'Format', Format/*###*/(date, "yyyy-mm-dd").
You are most likely getting that error as your date variable is a string and Format() requires you to have a numeric variable. My guess that error is from this
date is same as today_date, today_date comes from TOP5:get_dates() which returns strings. Keep the dates as numeric values and you will avoid all of these issues (there is no need to use Num(Char()) conversions, especially when you are starting from Today() which is a numeric value).
I suggest you read Date-Time parts from Scripting Guide, starting from this https://www.jmp.com/support/help/en/18.0/#page/jmp/datetime-functions-and-formats.shtml#
Yass
I took your suggestions into account and tried this method. However, I'm still facing an issue: my function returns a table with points in rows.
and I kept date = today_date; because when I run the script with today_date as a parameter directly, JMP doesn't respond. I don't understand why assigning date = today_date handles the run more efficiently.
TOP5:get_dates_percent = Function({},
    today_date = Today();
    start_of_month = Date Increment(Today(), "Month", 0, "Start");
TOP5:calculate_nok_percentages_over_time = Function({dt},
    {start_of_month, today_date} = TOP5:get_dates_percent();
    dt_results = New Table("NOK Percentages Over Time",
        New Column("Date", Numeric),
        New Column("Percent_NOK_ICT", Numeric),
        New Column("Percent_NOK_FCT", Numeric)
    // Set the format for the Date column
    Column(dt_results, "Date") << Data Type(
        Numeric,
        Format("Format Pattern", "<YYYY>-<MM>-<DD>", 10),
        Input Format("Format Pattern", "<YYYY>-<MM>-<DD>"),
        Format("Date Abbrev", 20)
    ) << Set Field Width(10);
    date = today_date;
    While(date >= start_of_month,
        {percent_nok_ict, percent_nok_fct} = TOP5:calculate_nok_percentages_for_date(dt, date);
        dt_results << Add Rows(
            {Format(date, "yyyy-mm-dd"), percent_nok_ict, percent_nok_fct}
        date = Date Increment(date, "day", -1);
    dt_results;
TOP5:calculate_nok_percentages_for_date = Function({dt, specific_date},
        Freq("Aucun(e)"),
        Weight("Aucun(e)"),
        invisible
            :File Name == nameFilesNok[k] & :Date >= start_of_month & :Date <= specific_date & Contains(:File Name, "GOLDEN") == 0
        nb_total_ict = 0;
        nb_total_fct = 0;
        nb_nok_ict = 0;
        nb_nok_fct = 0;
thank you in advance.
Points in cells mean missing data as you have numeric data type columns.
Yass
I'm uncertain if the problem is about the code's compatibility with my dataset.
I've attached a sample of my data table for your reference.
Your dates are numeric value if you mean that
dt = Open("$DOWNLOADS/TableData SVI PY.jmp");
vals = Column(dt, "Date") << get values;
show(vals);
Yass
yes my dates are numeric value
Yass
updates :)
I tried to use the function this way i did put all date on format Numeric. but as always i did get this error i think it's in Date Column:
"Cannot set the value of column 'Percent_NOK_ICT' because the row number (0) is not valid."
// Ouvrir le fichier de données
dt = Open("$DOWNLOADS/TableData SVI PY.jmp", invisible);
// Créer un résumé des données
    Freq("Aucun(e)"),
    Weight("Aucun(e)"),
    invisible
// Créer la table de résultats
// Obtenir les noms de fichiers NOK
// Boucle sur chaque jour depuis aujourd'hui jusqu'au début du mois
For(i = Today(), i >= Num(Date Increment(Today(), "Month", 0, "Start")), i -= 1,
    current_date = i;
    // Calcul des pourcentages NOK pour chaque jour
            :Nom de fichier == nameFilesNok[k] & Num(Date(:Date)) >= current_date & Num(Date(:Date)) <= Num(Today()) & Contains(:Nom de fichier, "GOLDEN") == 0
        nb_total_ict = 0;
        nb_total_fct = 0;
        nb_nok_ict = 0;
        nb_nok_fct = 0;
    // Assurez-vous que les totaux ne sont pas zéro avant de calculer les pourcentages
    If(total_nb_total_ict > 0,
        percent_nok_ict = 0;
    If(total_nb_total_fct > 0,
        percent_nok_fct = 0;
    // Ajouter une nouvelle ligne et définir les valeurs
    dt_results << Add Rows(1);
    last_row_index = N Rows(dt_results);
    dt_results:Date[last_row_index] = current_date;
    dt_results:Percent_NOK_ICT[last_row_index] = percent_nok_ict;
    dt_results:Percent_NOK_FCT[last_row_index] = percent_nok_fct;
// Affichage des résultats
dt_results;
It could be the Date() function which is causing issues (I'm not sure as I don't know how you have defined it).
Yass
You’ll find attached an updated version of the code that works for anyone interested in this subject !
dt = Open( "/D:/Project JMP/Tables/TableDataPY.jmp", invisible );
    Freq("Aucun(e)"),
    Weight("Aucun(e)"),
    invisible
results_table = New Table( "Results",
    New Column( "Date", Character ),
    New Column( "Percent NOK ICT", Numeric ),
    New Column( "Percent NOK FCT", Numeric ),
    New Column( "Total ICT", Numeric ),
    New Column( "NOK ICT", Numeric ),
    New Column( "Total FCT", Numeric ),
    New Column( "NOK FCT", Numeric )
For(day = Num(start_of_month), day <= Num(today_date), day = Date Increment(day, "Day", 1),
    current_date = Format(day, "yyyy-mm-dd");
        Num(Char(:Date)) == Num(current_date) & Contains(:Nom de fichier, "GOLDEN") == 0
    nb_total_ict = 0;
    nb_total_fct = 0;
    nb_nok_ict = 0;
    nb_nok_fct = 0;
    If(nb_total_ict > 0,
        percent_nok_ict = (nb_nok_ict / nb_total_ict) * 100,
        percent_nok_ict = 0
    If(nb_total_fct > 0,
        percent_nok_fct = (nb_nok_fct / nb_total_fct) * 100,
        percent_nok_fct = 0
    results_table << Add Rows(1);
    row_index = N Rows(results_table);
    results_table:Date[row_index] = current_date;
    results_table:Percent NOK ICT[row_index] = percent_nok_ict;
    results_table:Percent NOK FCT[row_index] = percent_nok_fct;
    results_table:Total ICT[row_index] = nb_total_ict;
    results_table:NOK ICT[row_index] = nb_nok_ict;
    results_table:Total FCT[row_index] = nb_total_fct;
    results_table:NOK FCT[row_index] = nb_nok_fct;
results_table << Save( "D:/Project JMP/Tables Resultats NOK percentages/Results.jmp" );
// Fermer toutes les tables ouvertes
Close( dt, "No Save" );
Close( dt_top5, "No Save" );
