SC003
Plot 2 set of data (x,y,z1), (x,y, z2) using Graph Builder; then correlate z1 and z2, same (x,y)
I am new to JMP and trying to get started.  Please help to advise the followings.
I have several sets of data, (x, y, z1), (x, y, z2,) ..., (x, y, zn).
1. For one set of data (x, y, z1), create a contour plot of z1 on (x, y), using Graph Builder
2. For one set of data (x, y, z1), plot only Z1 vs. (x_0, to x_m), using Graph Builder
3. Plot several sets of the data, say (x,y,z1) and (x,y, z2) using Graph Builder, and overlp the the data on the same plot
Appreciated.
Re: Plot 2 set of data (x,y,z1), (x,y, z2) using Graph Builder; then correlate z1 and z2, same (x,y)
See in JMP Help > Books > Essential Graphing. You can learn a lot from the descriptions, explanations, and examples. It doesn't take much time and it is time well spent.
I will also suggest that you can go to the JMP Starter Window to get you going quickly in JMP From the pull down menus go to:
View==>JMP Starter
