MDrake
Paired T Test in Bivariate Analysis
I received an example from a customer of some data analysis.  They performed 3 tests on the data.
  1. Linear Fit
  2. Orthogonal Fit Ratio = 1.000
  3. Paired t Test
I am able to get the first two through the Fit Y by X however I cannot find anywhere (online and in the software) to do a Paired t Test.
They did create two more columns for "Standard Value" and "Delta" which are formulas but are blank in the data table.
Any suggestions?
Thanks
jules
Re: Paired T Test in Bivariate Analysis
Hi @MDrake,
The typical way in JMP to perform a paired t-test using the Matched Pairs platform, which is available under Analyze > Specialized Modeling > Matched Pairs.
A less common way to perform the Paired t-test is using Fit Y by X just as you have before (with a continuous Y variable, and a continuous X variable), but before clicking the Red Triangle, hold down the Shift key on your keyboard. You will see the Paired T-test option now available in the menu. TheMatched Pairs platform has more options, but occasionally it's useful to run the Paired T-test through Fit Y by X.
I hope this helps,
@jules
Thierry_S
The Paired t-test platform has moved from the main "Analyze" menu to "Analyze" >  "Specialized Modeling" > "Matched Pairs".
To use this platform, your response needs to be split into columns (e.g. Before, After) with each row representing a unique item (e.g. Patient).
Cheers,
TS
Thierry R. Sornasse
jules
Hi @MDrake,
I hope this helps,
@jules
MDrake
Thank you that is excatly what I needed!
