aq
aq
PER file location does not exist
Every time I log into JMP I get a pop up that says "The PER file location does not exist, please enter an existing location." I've tried re-associating the license file without success. Any ideas?
Re: PER file location does not exist
Start up JMP in the "Run as Administrator" mode.  That should fix it from that point forward
aq
aq
I have tried starting up in "Run as Administrator" mode without success. I also tried deleting the license, adding it back in, and starting again in administrator mode.
Sounds like you need to contact JMP support
     support@jmp.com
Ares76
go to Help -> About JMP -> Install Checker;    look for "PER File Location" and that should give you your registery address.
and you should be able to see the path to the PER file and it should say it doesn't exit.    modify your registery and fix the file path and you should be good to go.
