JohnDMoore1
How to assign a data table reference to table opened by jmpquery?
Is there a way in JSL to assign a table created from a jmpquery execution?
Instead of:
dtBigClass = open("BigClass.jmp");
I would like to assign "dtBigClass" to a jmpquery that I just executed.
Many thanks,
John
David_Burnham
Re: How to assign a data table reference to table opened by jmpquery?
have you tried dt = bla bla bla where bla bla bla is the query ?
e.g.
New SQL Query(
	Version( 130 ),
	Connection( "JMP" ),
	JMP Tables(
		["Montgomery battery life ANOVA example" =>
		"\C:\Users\Pega-MAC\Downloads\Montgomery battery life ANOVA example.jmp"]
	QueryName( "SQLQuery1" ),
	Select(
		Column( "Material type", "t1", Analysis Type( "Nominal" ) ),
		Column( "Temperature", "t1", Analysis Type( "Nominal" ) ),
		Column( "Life (in hours)", "t1" )
	From( Table( "Montgomery battery life ANOVA example", Alias( "t1" ) ) )
) << Run;
where New SQL Query ... was gotten from the source script attached to the output data table.
-Dave
Mauro_Gerber
Level V
If you want to use the Query Builder, use the following code:
dt1 = Open("file1.jmp");
dt2 = Open("file2.jmp");
dtQuery =  dt1 << JMP Query Builder();
You can now work with both table.
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
