NetflixCrow956
Operation Rows
Hello everyone, I would like to know how to count the number of "OTPs" that are equal to 0 and make the division on the total number of LINES of OTP ? Thank you for your help
Re: Operation Rows
Create new formula column such as
:OTP == 0
then use summary to create new table using the new column as Subgroup (remove link to original data table if you don't need it)
select N Rows and N(1) columns and create new formula column with right click menu:
Ressel
Re: Operation Rows
Here's how you get the number of rows where OTP is equal to zero (see also here:(
dt = current data table () << select where (:OTP == 0); // suggest to have only the one table of interest for you open when testing this
num_selected = nrows(dt << get selected rows); // num_selected is now the number of rows where :OTP is equal to zero
Another way is via point & click:
  1. Convert the OTP column to Data Type "Character" under Column Info.
  2. Run a distribution analysis of the OTP column. This will show you how many rows with OTP equal to 0 there are.
Can you elaborate a little on the second part of the task, i.e., "...make the division on the total number of LINES of OTP."? I don't understand this. (Sorry.)
Re: Operation Rows
:OTP == 0
