PowerOx327
How do I condition a for loop to work only for a particular set of rows
I'm trying to manipulate a data table with a formula, but I only want it to read for a few rows.
Open( "$SAMPLE_DATA/Cars.jmp" );
r = Current Data Table() << Get rows where( :Make == "Mazda");
For( i = r[1], i <= r, i++,
:HeadIC[i] = :HeadIC[i]/2
Show(r);
How do I make it so that it only iterates for those selected rows?
SamGardner
Re: How do I condition a for loop to work only for a particular set of rows
In your example, since you have made the vector with the row numbers, you can also use "For Each()".  This would be faster, especially for a larger data table (with may rows).
for each({cr,ii}, r,
	:headic[cr] = :headic[cr]/2
For Each() is new function introduced in JMP16, so if you are using older version of JMP you won't find it in scripting index (and it will give an error). You could convert it to for-loop if you wanted to:
/*For Each({cr,ii}, r,
For(ii = 1, ii <= N Items(r), ii++,
	cr = r[ii];
	:headic[cr] = :headic[cr]/2;
For Each(names, container, locals, body) (jmp16 help)
6 REPLIES 6
Ressel
Like this?
For Each Row( If ( :Make == "Mazda", :HeadIC = :HeadIC/2 ));
SamGardner
Ressel
Please demystify this for me:
// specifically, where do {cr,ii} come from and what do they do?
Not a coder. Couldn't find this in the Scripting Index. Haven't checked the Scripting Guide yet.
PowerOx327
Hi, I'm unsure how to use that function, I cant find it in the scripting index, can you show an example? When I try to run the code that you gave, errors pop up.
	cr = r[ii];
Ressel
That's strange. Both work just fine for me. Try again posting the full code of each solution into a separate script window. Close everything else. Run first the code from one script window, confirming that the code does what it is supposed to do. Then, close everything again apart from the other script window containing the code you still need to test.
