BookmarkSubscribeRSS Feed
sornasst
Feb 2, 2016
Oneway: TTest using the "By" variable in script
The following code does not work: Oneway, t-test does not recognize the "Column ( i )" as a valid argument in the "Where" clause.
Names Default to Here(1);
dt = Current Data Table();
For(i=92, i<= N Col (dt),i++,
   ow = Oneway(
  Y( :Delta mRSS W24 ),
  X( :TRT01P ),
  t Test( 1 ),
  invisible,
  Where( Column ( i ) == 3 )
   report(ow)[1]<<journal;
ms
Jun 23, 2011
Solution
Re: Oneway: TTest using the "By" variable in script
Try
Where(As Column(Column(i)) == 3)
Or simply
Where(:(Column(i)) == 3)
sornasst
Feb 2, 2016
Correction,
The script got messed up when I pasted it.
   ow = Oneway(
  Y (: Delta mRSS W24),
  X ( :TRT01P ),
  t Test( 1 ),
  invisible,
   report(ow)[1]<
ms
Jun 23, 2011
Solution
Try
Or simply
