OnRecalc()
tom_abramov
Oct 13, 2015
Is there some way to run "OnRecalc()" method as OnClose() of the window platform.
For example, I run bivariate with AutoRecalc=on and I would like every time the user excludes some observation to run some code.
Thank you.
Code example - I would like to open/close correlation outline depends on the r value:
win = New Window("",
obj = Bivariate( Y( :Weight ), X( :Height ),
Density Ellipse( 0.95, {Line Color( {213, 72, 87} )} ),
Automatic Recalc(1) ));
rep = obj << report;
r_value = rep[NumberColBox("Correlation")][1];
if(r_value>0.75,rep[OutlineBox(2)]<<Close(0),rep[OutlineBox(2)]<<Close(1));
Jun 22, 2012
Solution
You can use "Make Row State Handler" to add code either to the data table or to the Frame Box(), which will execute whenever there is a change to row selection, exclusion, etc.
1 REPLY
Jun 22, 2012
Solution
