UberBock
Not sure is this is possible...
I have a data table that has a column which is either a 1 or 2 (its called channel).  In another column there is a designation of a 'test'.  It is numeric like 10 or 20 or 30.
What I would like is to create another column that concates all the 'test' for channel 1 and then for channel 2.  So each line of data will have a column that has the concat of the test based on channel.   So it may look like 10|30|80 for channel 1 but 20|40|30 for channel 2.
The data table could have 1000's lines of result data from different tests.  I am interested in seeing what channel uses which test by machine.  Since different machines can have different tests on different channels.
I might also need to add another qualifier.  So that the 'test' is  concate by not only by channel channel but also machine (which denoted by a serial number).
This would be in script for to include into a post-script query.
Any suggestions are appreciated!
Re: Not sure is this is possible...
Here is a script that calculates the tests into a single column.  Just make your table with the testnumber data the active data table, by clicking on it, and then run this script.
names default to here(1);
// Set up a handle to point to the example data table
dt=current data table();
// Find the testnumbers for each machine/channel combination
dtSumm = dt << summary(
	Group( :Machine, :Channel,:testnumber),
	N,
	Link to original data table(0)
// Create a new table to accumulate the testnumbers into a single value
dtFinal = New Table("Concat Test Number",
	New Column("Machine", character),
	New Column("Channel"),
	New Column("Tests", character)
For(i=1,i<=N Rows(dtSumm), i++,
	If(i==1,
		dtFinal << add Rows(1);
		dtFinal:Machine[N Rows(dtFinal)] = dtSumm:Machine[i];
		dtFinal:Channel[N Rows(dtFinal)] = dtSumm:Channel[i];
		dtFinal:Tests[N Rows(dtFinal)] = char( dtSumm:testnumber[i])
	dtSumm:Machine[i] != dtSumm:Machine[i-1] |
		dtSumm:Channel[i] != dtSumm:Channel[i-1]
	dtFinal:Tests[N Rows(dtFinal)] = dtFinal:Tests[N Rows(dtFinal)] || "/" || char( dtSumm:testnumber[i])
// Merge the new column back to the origianl table
dt = dt << Update(
	With( dtFinal ),
	Match Columns( :Machine = :Machine, :channel = :Channel )
close( dtSumm, nosave );
close( dtFinal, nosave );
13 REPLIES 13
Doing what you want will not be very difficult. However, your description is a little bit confusing. Would it be possible for you to provide a small example of the data table, and what you want as this new column you are proposing?
UberBock
Sure attached is an example table.  Only 1 machine is listed but more than 1 could in in the table.  Also, over time the testnumber by channel could change.
I can tabulate the data to get which channel has which test number by date but is there a way to indicate that in a column for each line of data.  The testinitiationdatelocal could be used as shortdate to get the day.
UberBock
I can tabulate the data to get which channel has which test number by date but is there a way to indicate that in a column for each line of data.  The testinitiationdatelocal could be used as shortdate to get the 'date'
	N,
	If(i==1,
dt = dt << Update(
	With( dtFinal ),
UberBock
Wow!  amazing!  Thank you!
UberBock
So how would I include a date element?  In the examplev2 there is a column with date.  1 Data point for channel 2 uses Test 40 so this should show up for data from that date (7/4).  It should not show up for the other lines for other dates for channel 2 since those dates test 40 was not used.
All I think that needs to be
	Group( :Date, :Machine, :Channel,:testnumber),
	N,
	New Column("Date"),
	If(i==1,
		dtFinal:Date[N Rows(dtFinal)] = dtSumm:Date[i];
dt = dt << Update(
	With( dtFinal ),
	Match Columns( :Date = :Date, :Machine = :Machine, :channel = :Channel )
done, is to add Date in as an additional classifying column, like "Machine", and "Channel".
UberBock
I see.
When I applied it the scrip worked.  Except I noticed in the data some lines had it missing.  I cant quite figure out what is going on with these lines and why it will not work.
I failed to add the Date[i] vs. Date[i-1].  I added that to line 29, and the script appears to be working.......please check it out
	N,
	New Column("Date"),
	If(i==1,
	dtSumm:Date[i] != dtSumm:Date[i-1] | dtSumm:Machine[i] != dtSumm:Machine[i-1] |
dt = dt << Update(
	With( dtFinal ),
