  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Rehrig76
My Home Window no longer has the Recent Files window
Hi All,
Not sure how I did it, but my Home Window is screwed up. The Window List is not longer in the Home Wndow, and the Recent Files list is not longer there.  I can't click on any of the menu drop-downs either(although I can if I open a data table ).   Very frustrating - I've uninstalled and re-installed JMP, and it looks exactly the same.  If anyone has a clue, please help.
Thanks,
-Mike
Rehrig76
Re: My Home Window no longer has the Recent Files window
This didn't work,  I tried it Friday.  I actually just fixed this by applying the fix for someone that had the same issue in JMP 12 - Go to User\AppData\Roaming\SAS\JMP an there was an entry in there for Homelayout.  I deleted it, and restarted JMP, and everything is back to normal.
8 REPLIES 8
Have you tried going to the View menu > Home Window Panes > Revert to Factory Layout? It sounds like you might need to open a data file first to see the menu.
Dan Obermiller
Mike,
Can you get to "View" drop down menu?  If so, you should be able to reset Home window there.  View > Home Window Panes.
HTH
albertpost
How do you do this in JMP14?  I seem to be having the same problem.
mischa869
Yes! I did it in my JMP 14 and it worked (thank G-d!)
mischa869
I went to User\AppData\Roaming\SAS\JMP and there was an entry in there for Homelayout.  I deleted it, and restarted JMP, and everything is back to normal.
mischa869
I went to User\AppData\Roaming\SAS\JMP an there was an entry in there for Homelayout. I deleted it, and restarted JMP, and everything is back to normal.
What Dan said!
Rehrig76
