This didn't work, I tried it Friday. I actually just fixed this by applying the fix for someone that had the same issue in JMP 12 - Go to User\AppData\Roaming\SAS\JMP an there was an entry in there for Homelayout. I deleted it, and restarted JMP, and everything is back to normal.
