BookmarkSubscribeRSS Feed
mcstagger
Oct 6, 2014
Multivariate Analysis Using a Filter Variable
I have a data set that includes data for multiple user groups which are identified via a separate variable. Is there a way to use this filter variable or any other variable as a filter when running a multivariate analysis?
Right now it seems as though I have to create subsets for the individual groups I want to run this on.
ms
Jun 23, 2011
Solution
Re: Multivariate Analysis Using a Filter Variable
Maybe the By-option, supported by most platforms, will do what you want. In the Multivariate dialog, select the filter variable column and click "By".
It will result in multiple reports within the same window but otherwise completely independent.
ms
Jun 23, 2011
Solution
mcstagger
Oct 6, 2014
As expected, the obvious answer was in front of me. Thanks!
bill_worley
Jul 2, 2014
Mcstagger,
Are you familiar with the local data filter and/or the data filter under the rows menu? You can access the local data filter under the red hot spot for multivariate>script>local data filter.  Add the variable you want to use as a filter.
The data filter under rows also allows you hide and exclude points.  Use the same procedure to add the filter variable.  Click show and include to hide and exclude.
