Dear all,
I generated a model from 20 data generated with a DoE.
I also run in parallel 20 runs designed with a LHS on the same design space.
I would like to compare the observed responses obtained with the LHS to the predicted responses obtained with the DoE.
Which kind of procedure would you suggest to validate/verify the initial DoE model ?
I used equivalence testing but it looks as a stringent test (I mean, a model seems to be highly performing to pass such a test).
Please note that I do not have JMP Pro,
Many thanks,
Hugo
@martindemel
