BookmarkSubscribeRSS Feed
tajrida
Community Trekker
Apr 8, 2015
Model Comparision Addin
Wondering if there is an "add-in" available for model comparison? (free or purchase)
Thanks
David_Burnham
Jul 13, 2011
Solution
Re: Model Comparision Addin
JMP Pro contains a Model Comparison Platform.
If you are simply building different regression models and want to compare their characteristics then this add-in might be useful:
Model Diagnostics and Transformations
-Dave
-Dave
David_Burnham
Jul 13, 2011
Solution
-Dave
-Dave
bill_worley
Jul 2, 2014
There is a way to compare models for continuous data by using the Fit Y by X platform. As long as you save your model prediction formulas you can plot actual (Y) by predicted (X) for the models you want to compare.  You can use multiple X's and the you will see the plots side by side.  You then need to fit a line to each by holding your control key down first and then selecting "Fit Line" under the red hot spot for one of the Bivariate fits.
Regards,
Bill
