Jacksmith12
Merging two columns
i am trying to join two data frames but cannot get my head around the possibilities Python has to offer.
First JMP data file:
ID MODEL   REQUESTS ORDERS1  Golf    123      4
2  Passat  34       5
3  Model 3 500      8
4  M3      5        0
Second JMP data file:
MODEL   TYPE  MAKEGolf    Sedan VolkswagenM3      Coupe BMWModel 3 Sedan Tesla
What I want is to add another column in the first dataframe called "make" so that it looks like this:
ID MODEL   MAKE       REQUESTS ORDERS1  Golf    Volkswagen 123      4
2  Passat  Volkswagen 34       5
3  Model 3 Tesla      500      8
4  M3      BMW        5        0
 Any suggestions how can I start?
ian_jmp
Re: Merging two columns
Looks like you need the menu option 'Tables > Join'. Your post got a little scrambled, but using the tables attached and setting up the dialog like this:
you should get close. You could also look at virtual joins.
