BookmarkSubscribeRSS Feed
ram_asra_gmail_
Mar 21, 2013
Local data filter
HI All,
I am using local datafilter to see various component one by one.
i have targets also in the split column. i always want targets to be black in color as shown in the chart1 below
when i am not clickcking on tgt, colors remains same, and match to legend.
but the moment i select Tgt, my all lines turns into black, whichever split i select lines remains black.
Any help or suggestions will be appreciated.
Thanks
Ram
Chart1
chart2
chart3
ian_jmp
Jun 23, 2011
Re: Local data filter
If I understand correctly 'tgt' is some kind of target relating to the y values (and independent of 'Split'). If that's so, the normal way to handle this in JMP would be as meta-data relating to column y (or as a 'column property' to use JMP language).
In the attached version of your table I've added an axis property, but a spec limit property may be more appropriate. Click on the '*' next to 'y' in the Columns Panel'. Then run the saved script.
