BookmarkSubscribeRSS Feed
kthompsn
Sep 22, 2016
JMP13 - Bug & Patch - Teaching scripts - Distribution Calculator
Problem:
Many of the Teaching scripts no longer work correctly in JMP 13.
Fix:  (may require admin access for a permanent fix, Based on JMP Pro 13 for Windows, )
Edit the underlying *.JSL script   (on Windows, \Program Files\SAS\JMPPRO\13\Samples\Scripts\...
Look for  "<<Script( "    (spaces and capitalization may change from jsl to jsl
If the "<<Script(" code is within a RadioBox() or a ComboBox()
    comment out (or delete) the "<<Script(" and the corresponding ")"
Not all of the "<<Script( ... )"  are incorrect.
Be sure to test the JSL before and after the chage
Reason ?:
It appears that JMP made a change in JSL syntax some version ago
    to:     RadioBox( contents, jslcode )
Version 12 documents the new syntax but retained the ability of running the old
Version 13 no longer allows the old syntax
