011717
Iterate script over different table
I have this defecting level which determines the number of times it will iterate.
dtparms << Subset( By( :Defecting_Level ), All rows, Selected columns only( 0 ), columns( :Parameter, :CL_LL, :CL_UL, :MD_LL, :MD_UL ) );
dtParms1 = Data Table( "Defecting_Level=1" );
dtParms2 = Data Table( "Defecting_Level=2" );
This is the code that needs to iterate depending on how many defecting levels there are. My problem is can I iterate through different tables using the same script? Or how can I repeat this process depending on the number of defecting levels? Like for example, my defecting level is 3. Then this code needs to run three times, iterating through the three tables that has been subset. Thanks
deftb << New Column( "MD1", numeric );
parameters = Column( dtParms1, "Parameter" ) << get values;
deftb_colnames = deftb << get column names( string );
parameters = Associative Array( Eval( parameters ) );
deftb_colnames = Associative Array( Eval( deftb_colnames ) );
parameters << Intersect( deftb_colnames );
params = parameters << get keys;
For( i = 1, i <= N Items( params ), i++,
	foundRows = deftb << get rows where( As Column( deftb, dtParms1:Parameter[i] ) < dtParms1:CL_LL[i] & Is Missing( deftb:MD1 ) == 1 );
	deftb:MD1[foundRows] = dtParms1:MD_LL[i];
	foundRows = deftb << get rows where( As Column( deftb, dtParms1:Parameter[i] ) > dtParms1:CL_UL[i] & Is Missing( deftb:MD1 ) == 1 );
	deftb:MD1[foundRows] = dtParms1:MD_UL[i];
Re: Iterate script over different table
I am sure, that the JSL below, as written, will not work.  The sample code that was provided had pointers to data tables not defined, so therefore, I am making some assumptions that may not be exactly correct.  However, if you follow the logic and syntax I provide, you should be able to get an idea of how to have your one piece of code used to loop across whatever number of input parameters specified
// By specifying the variable to hold the data table names
// that will be created from the Subset with the By clause
// the variable specified becomes a List with an element
// for each table created
theTables = dtparms << Subset(
	All rows,
Show( theTables );
For( k = 1, k <= N Items( theTables ), k++,
	parameters = Column( theTables[k], "Parameter" ) << get values;
			As Column( deftb, column( theTables[k],"Parameter")[i] ) < column( theTables[k], "CL_LL")[i] &
		deftb:MD1[foundRows] = column(theTables[k],"MD_LL")[i];
			As Column( deftb, column( theTables[k],"Parameter")[i] ) < column( theTables[k], "CL_UL")[i] &
		deftb:MD1[foundRows] = column( theTables[k],"MD_UL")[i];
9 REPLIES 9
	All rows,
Show( theTables );
011717
Thank you for a quick answer! I have a follow up question tho,
deftb << New Column( "MD1", numeric ); => which will be the storage of the iterated values, should be (MD1, MD2, MD3..) according to the number of iterations. For example, iteration for table 1 values will be stored in MD1, iteration for table 2 values will be stored in MD2 and so on. I tried adding this line but it doesn't work:
MD = {"MD1", "MD2", "MD3", "MD4", "MD5", "MD6"};
deftb << New Column( MD[k + 1], numeric );
Thanks for the help
Both of the below pieces of code work great for me, as long as the deftb data table reference has been set, and the theTables list has been populated.  Since the script did not work for you, what error messages were there in the log?
// or, why go through all of the work to create the list MD
// when you can easily create the character string required
// for the column name as shown below
deftb = Current Data Table();
	deftb << New Column( "MD" || char[k + 1]), numeric )
011717
Now it's working, thanks for the swift explanation. And last question, after creating the column storage for the values, this loop shows an error: Subscript Range{1} in access or evaluation of 'theTables[k]' , theTables[/*###*/k]
        As Column( deftb, Column( theTables[k], "Parameter" )[i] ) < Column( theTables[k], "CL_LL" )[i] &
        Is Missing( deftb:MD[k + 1] ) == 1
    deftb:MD[k + 1][foundRows] = Column( theTables[k], "MD_LL" )[i];
        As Column( deftb, Column( theTables[k], "Parameter" )[i] ) < Column( theTables[k], "CL_UL" )[i] &
    deftb:MD[k + 1][foundRows] = Column( theTables[k], "MD_UL" )[i];
Is it because of my MD[k+1]?
To figure out what is going on here, all you need to do, is to determine the value of the variable k and it will tell you why referencing theTables[k] is pointing to an invalid subscript.  Typically this is because you have either used a For() loop with k as the index value, and in the specification of the For() loop, you are incrementing k beyond the number of elements of theTables list.  Or, the variable k what used in a previous part of the script, and when it is referenced at this point, the value of k is inappropriate.
If you hover over any of the references to the variable k in your script, it will display what the current value of k is.  You should be able to then find out where the value came from.
one last note....since you are not initializing your variables at the beginning of your script, the values of the variables will be set to the values they were at the last time the script ended.  Therefore, that can be causing the issue too.
011717
So I'm kinda lost again with these loops, and I'm only getting the value of 6 inside MD1 column only instead of the values from each table from theTables and placed inside their respective MDs. SOrry I'm really confused with the For loop in jmp
    By( :Dispo_name ),
    All rows,
//create columns
For( n = 1, n <= N Items( theTables ), n++,
    deftb << New Column( "MD" || Char( n ), numeric )
//loop through each table and store value in MDs
    Show( params );
            Is Missing( deftb:MD ) == 1
        deftb:MD[foundRows] = Column( theTables[k], "MD_LL" )[i];
        deftb:MD[foundRows] = Column( theTables[k], "MD_UL" )[i];
1. Please attach a sample data table so I can test the code against real data.
2. Please provide a mockup of what you expect the final data table to look like.
011717
I've attached a sample data table, code and template.
Attached img is the expected table output,
I have corrected the syntax issues with the code, so it is generating values.  However, it does not at all match your PNG file output.  You need to step through the code and see where the code diverges from the logic you are thinking it is supposed to be doing.
//sample data
//tb = Open( "C:\Users\1000258123\Desktop\Australian Tourism.jmp" );
deftb = Data Table( "Australian Tourism" );
//sample template
//parms = Open( "C:\Users\1000258123\Desktop\defecting_template.jmp" );
dtparms = Data Table( "defecting_template" );
dt_Params= dtparms << Subset( By( :Level ), All rows, Selected columns only( 0 ), columns( :Parameter, :lower_value, :upper_value, :defectCode_lower, :defectCode_upper ) );
//create columns
For(n = 1, n <= N Items(dt_Params), n++,
	deftb << New Column( "MD" || char(n), numeric )
//looping in tables;
For(k = 1, k <= N Items(dt_Params), k++,
	parameters = Column( dt_Params[k], "Parameter" ) << get values;
	Show( params );
//determines if upper and lower parameter values are within the range of the upper_value & lower_value(defecting_template, then give its respective defect_Code in MDs
	 foundRows = deftb << get rows where(ascolumn(deftb, (column(dt_Params[k],"Parameter")[i]) ) < as column(dt_Params[k], "lower_value")[i] & Is Missing(as column("MD"||char(k))) == 1);
	 //foundRows = deftb << get rows where(Column(deftb, (column(dt_Params[k],"Parameter")[i]) ) < column(dt_Params[k], "lower_value")[i])// & Is Missing(column("MD"||char(k)) == 1));
	 column(deftb,"MD"||char(k) )[foundRows] = column(dt_Params[k],"defectCode_lower")[i];
	 foundRows = deftb << get rows where(ascolumn(deftb, (column(dt_Params[k],"Parameter")[i]) ) < as column(dt_Params[k], "upper_value")[i] & Is Missing(as column("MD"||char(k))) == 1);
	 //foundRows = deftb << get rows where(As Column(deftb, column(dt_Params[k],"Parameter")[i] ) < column(dt_Params[k], "upper_value")[i] & Is Missing(column("MD"||char(k))) == 1);
	 column(deftb,"MD"||char(k) )[foundRows] = column( dt_Params[k],"defectCode_upper")[i];
//convert blank values to zero
col_prefix = "MD";
For( i = 1, i <= N Items( dt_Params ), i++,
	missing_rows = deftb << get rows where( Is Missing( As Column( deftb, col_prefix || char(i) ) ) );
	If( N Rows( missing_rows ) > 0,
		Column( deftb, col_fix || char(i) )[missing_rows] = 0
