BookmarkSubscribeRSS Feed
gkrjqu7
Not applicable
Feb 16, 2019
Is there a function that can replace the entire table inside a table box?
I have a empty/default table box poped up, and I wanted to replace the entire table box using the script below. Is there a way to update [table box] with
This script I am using now is tedious:
button box("UPDATE",
    dtmain = Open(filename, invisible);
    tb << delete row( 1 );
// 50 lines of delete row()
tb << insert row( 1, {"a", 1} ); tb << insert row( 1, {"b", 2} );
// 50 lines of insert row()  );
Thanks in advance:)
Jun 22, 2012
Solution
Re: Is there a function that can replace the entire table inside a table box?
I have found it that it is easier to delete and replace the table, rather than updating.  The simple script below illustrates that methodology
New Window( "The Table",
	vlb = V List Box(),
	theButton = Button Box( "UPDATE",
		Try( theTable << delete );
		theList = {};
		Insert Into( theList, dt:Name[Random Integer( 1, 40 )] );
		theTable = Table Box( String Col Box( "Name", theList ) );
		vlb << append( theTable );
// Initialize the table
theList = {};
Jun 22, 2012
Solution
	vlb = V List Box(),
		theList = {};
theList = {};
