BookmarkSubscribeRSS Feed
utopie2025
Community Member
Feb 5, 2016
Idea : Decision Trees Leaf Report for Boosted and Bootstrap Partition Modeles
Dear JMP Development Team
Interpreting Big Bootstrap Forests are not that easy and JMP Pro doesn't help much for that as the Show Trees option is not very practical and looks more like a gadget than a true knowledgeable option.
To overcome that limitation it would be very interesting if you could export easily the leaves report into Excel
This possibility is aready available in classical Decision Trees but not in Bootstrap Forests
Leaf Report in the classical Decision Tree module  is very pratical
Its tabular format makes easy to perform analysis off the cutting points
Many thanks
Arnaud
