I can't locate files for training on Correlation and Regression.
Apr 6, 2020 02:20 PM(5477 views)
The file "impurity.txt" is not in my sample data. I just updated my JMP to 15.1 and I still can't find this file. Is there somewhere else I can pull these files from?
If you are using JMP in the virtual lab, click the "Refresh your Data" link (on the far right on the course landing page). If you are using your own copy of JMP, you can download the files using the Download Course Materials link.
