lstrack
I can't locate files for training on Correlation and Regression.
The file "impurity.txt" is not in my sample data.  I just updated my JMP to 15.1 and I still can't find this file.  Is there somewhere else I can pull these files from?
Re: I can't locate files for training on Correlation and Regression.
If you are using JMP in the virtual lab, click the "Refresh your Data" link (on the far right on the course landing page). If you are using your own copy of JMP, you can download the files using the Download Course Materials link.
If you're trying to find the files within JMP in the virtual lab, see the Getting Started and Instructions for the JMP Virtual Lab.
I hope this helps!
Mia
What are you accessing that is requesting you to open "impurity.txt". Is it a tutorial?
You sure it's not impurity.jmp?
Where did you find this data table?
I hope this helps!
Mia
Parz
I refreshed the data but still can't find the impurity file, any suggestions of what should I do?
Thank you
Paola
Here is one of the impurity data tables.  Not sure if this is the one you want?
