Jeff, thanks for getting back to me.
Bear with me =I I haven't worked with JMP for some time so I forgot all the secret handshakes ;)
Here's one of these cases. I've created a table with all the data I need to create a graph (or to do some an alysis). I've used Graph Builder to create the graph and chose "Save Script / To Data Table" - and there it is below the data table:
Now I save the data table to SBW.jmp - done.
After some time I learn that some of the data needs to be corrected, so I reopen the data table, and the graph is gone - bummer.
From what I learned from you, the script is actually there (having a green triangle), but not where I had expected it. Maybe subheadings "Graphs", "Analyses", ... separating the green triangles would help?
I also had tried to create a Project, but I didn't find the information to understand how.
Thanks again,
Knut
