gurtejsbains
How to save custom quantiles to a table
I have a continuous variable which I broke down using a custom quantile (instead of normal quantile, default in JMP). My custom quantile is 0%, 25%, 50%, 75% and 100%. The distribution platform shows the output but how can I save this to a table? If I click the red triangle --> save, I only see the option to save default JMP normal quantiles only.
Any ideas about how I can save the custom quantiles rather than the default JMP normal quantiles?
Thanks
Re: How to save custom quantiles to a table
Right-click on the table with the quantiles and select Make Into Data Table.
gurtejsbains
Mark, Appreciate the reply. I was looking for a solution to add quartiles to the main data table. This was I can work on the base dataset along with quartiles. I can definitely use your solution and then create a formula column.
