75Innovation
How to save custom quantiles to a table
I have a continuous variable which I broke down using a custom quantile (instead of normal quantile, default in JMP). My custom quantile is 0%, 25%, 50%, 75% and 100%. The distribution platform shows the output but how can I save this to a table? If I click the red triangle --> save, I only see the option to save default JMP normal quantiles only.
Any ideas about how I can save the custom quantiles rather than the default JMP normal quantiles?
Thanks
Re: How to save custom quantiles to a table
Right-click on the table with the quantiles and select Make Into Data Table.
75Innovation
Mark, Appreciate the reply. I was looking for a solution to add quartiles to the main data table. This was I can work on the base dataset along with quartiles. I can definitely use your solution and then create a formula column.
nanayOf3
How do you write this action into a script?
Let JMP script it for you (if you have JMP16+ even easier)
1. Open your table
2. Create your distribution
3. Right click on the Quantiles table box and Make into Data table
Slightly Script from Enhanced log:
// Open Data Table: Big Class.jmp // → Data Table("Big Class") Open("$SAMPLE_DATA/Big Class.jmp"); // Launch platform: Distribution Data Table("Big Class") << Distribution(Continuous Distribution(Column(:weight))); // Make TableBox into a Data Table // → Data Table("Untitled") Local({obj}, obj = Data Table("Big Class") << Distribution( Continuous Distribution(Column(:weight)) ); Report(obj)["weight", "Quantiles", Table Box(1)] << Make Into Data Table; obj << Close Window; );
The script can be "auto"built without enhanced log but you have to collected the scripts from different places (from distribution platform and from result tables table script)
