Alicia
How to rename column for multiple PDF tables
Hi there,
I've wrote a script that enables me to extract a table from multiple pdf files. Each table opens and the table name is matched to the file name.
I've realised the format of the pdfs isn't always consistent and so the header for column 3 can be different. Therefore, I would like to incorporate a function into my script that renames column 3 as "Property" for all the tables. I've tried the Set Name() function but it's not working. Perhaps it's in the wrong place?
// Prepare a directory
tempdir = "C:\folder path";
// Read PDF's
file_lst = Files In Directory( tempdir );
table_lst = {};
For( i = 1, i <= N Items( file_lst ), i++,
	Insert Into( table_lst, Open( tempdir || "/" || file_lst[i],
	PDF Tables(
		Table(
		table name(file_lst[i]),
		add rows( page( 1 ), Rect( 0.4143, 5.3995, 7.5889, 6.6781 ) ),
		column(table_lst[i],3) << set name("Property")
Any help on this would be hugely appreciated!
Re: How to rename column for multiple PDF tables
I attempted your approach, and continued to get the error. Therefore I changed to the approach that I used in my last entry. However, when I pasted it into the entry, I left a statement out of the code.
insert into( table_lst, dt );
I believe if you use the code below, it will work for you
// Read PDF's
table_lst = {};
	dt = Open(
		PDF Tables(
			Table( table name( file_lst[i] ), add rows( page( 1 ), Rect( 0.4143, 5.3995, 7.5889, 6.6781 ) ) )
	Column( table_lst[i], 3 ) << set name( "Property" );
8 REPLIES 8
I believe the below rework of your code will properly rename the column
// Read PDF's
table_lst = {};
	dt = Open(
		PDF Tables(
Alicia
Many thanks for your reply @txnelson . Unfortunately I get the follow JMP alert when I run the script:
is outside the "for" loop.
If you copy/paste it into the loop, should work.
Guillaume
Georg
Balanced Parantheses are crucial,
I like very much the option "Reformat Script" (--> Edit-Menu, or crtl-m) to test for correct syntax.
Georg
Alicia
Many thanks for the help!
I've updated my script as below and it works however after all the tables are open the same JMP Alert comes up again.
Any suggestions?
tempdir = "C:\filepath;
// Read PDF's
table_lst = {};
	Insert Into(
		table_lst,
		Open(
			PDF Tables( Table( table name( file_lst[i] ), add rows( page( 1 ), Rect( 0.4143, 5.3995, 7.5889, 6.6781 ) ) ) )
Georg
The colors already show you that you have not ended the string tempdir by ";
Reformating the script really helps to see this.
Georg
// Read PDF's
table_lst = {};
	dt = Open(
		PDF Tables(
Alicia
Got it working. Really appreciate all the help!
