Fabrice_L
How to permanently change the green color and all JMP graphs ?
By default, many graphs in jmp (particularly in the graph builder) use a green color, which, I clearly do not like. I can change the color or each graph, but this is not very practical. I know Preferences -> Styles, Preferences -> Style, Preferences -> Platforms, but I can not find a way to change this color... I have asked this question in the past, with no answer. Really, a software like JMP can do so many things but can not change the preference of the default color used in all graphs ?
Thanks for any help. F.
ih
Super User (Alumni) ih
Re: How to permanently change the green color and all JMP graphs ?
Ah, that color green.  I don't know how to find this in the preferences dialog, but trying running this in a JSL script:
Preferences( Histogram Color( blue ) );
12 REPLIES 12
ih
Would Preferences > Graphs > Color Themes (specifically categorical) help?
Fabrice_L
Thanks for your answer, but I don't think this is the solution (unless I miss something). This is a the color theme to represent different values of a categorical variable. I have found in Preferences -> Platforms -> Distributions how to change the default value of the histogram, but this is not the same value used in the graph builder. :(
ih
Fabrice_L
Yeah ! This works ! There is a thousand of options ins the preferences, but not this one ! It seems they have just forgotten this one... Thanks !
nascif_jmp
I recommend adding this to the JMP Wish List so that it can be tracked and other users can vote on it.
Fabrice_L
DOne !
mlo1
The Graph and Window Background Colour should do the job
Fabrice_L
Thanks for your answer, but this is not the solution. This panel permits to change (for example) the color of the background of a graph, or the color of the background of the window; this works and affect the graph builder (I've tried, see attached image), but the green color of the histogram.
Right click on the legend and select Fill Color to change the color of the Historgram
