Simona1
How to join more than 2 tables?
How can I join more than 2 tables?
Simona1
Re: How to join more than 2 tables?
Thank you for your responses, I am really new to JMP. I have 22 tables. I tried to use the "join" and join 1 by 1 but after ~10 tables JMP would crash. I tried Building Query but some data points were missing from the tables. I end up using the Update function and it worked fine, except that I had to do one by one. Thank you all again!
Using a virtual join, you can join as many tables as you want. You can also use the Query Builder to join multiple tables
mlo1
Did you check the following:
Joining multiple tables and output
Simona1
