lala
Level IX
How to implement these two figures in the same diagram?
Thanks Experts!
Use both groups x:
lala
Level IX
回复: How to implement these two figures in the same diagram?
d0=Open("$SAMPLE_DATA/Big Class.jmp");
d0 << Select Where( age < 16 );
dt = d0 << Subset(
	Output Table( "test" ),
	Selected Rows( 1 ),
	selected columns( 0 )
Try( dt << Delete Table Property( "Source" ) );
d2 = dt << Summary(
	Group( age ),
	Freq( 0 ),
	Weight( 0 ),
	Link to original data table( 0 ),
	Output Table( "tem" )
Column( d2, 2 ) << set name( "row" );
mi = Min( d2[0, "row"] );
ca = "ratio";
New Column( ca );
Column( ca ) << Formula( Round( row / mi, 2 ) );
d2 << run formulas;
Column( ca ) << deleteFormula;
dt << Update( With( d2 ), Match Columns( age = age ) );
Close( d2, nosave );
Current Data Table( dt );
ca = "list";
New Column( ca );
	If( Row() == 1 | age != Lag( age, 1 ),
		r = Row();
		1;
		Floor( (Row() - r) / ratio + 1 )
d0 << run formulas;
p1 = dt << Graph Builder(
	Size( 690, 466 ),
	Show Legend( 0 ),
	Show X Axis( 0 ),
	Show Y Axis( 0 ),
	Variables(
		X( :weight ),
		Y( :height ),
		Group X( :age, Show Title( 0 ) ),
		Color( :sex )
	Elements(
		Bar(
			X,
			Y,
			Legend( 5 ),
			Response Axis( "X" ),
			Summary Statistic( "Sum" )
		Dispatch(
			"graph title",
			TextEditBox,
			{Hide( 1 )}
		Dispatch( {}, "X title", TextEditBox, {Hide( 1 )} ),
		Dispatch( {}, "Y title", TextEditBox, {Hide( 1 )} )
p2 = dt << Graph Builder(
	Size( 686, 404 ),
	Show Legend( 0 ),
	Show X Axis( 0 ),
	Show Y Axis( 0 ),
	X Group Edge( "Bottom" ),
	Variables(
		X( :list ),
		Y( :height ),
	Elements(
		Bar( X, Y, Legend( 5 ), Summary Statistic( "Sum" ) )
		Dispatch(
			"graph title",
			TextEditBox,
			{Hide( 1 )}
I would say you cannot (and should not) have them in same graphs as they are displaying different information (at least based on your graph builder scripts). You could combine then into single "report" if needed by using Combine Windows
Level XII
you could rescale "list" by x 30 and use it on the X axis - which will  give this graph:
View more...
dt << New Column( "list*30",
	Formula( :list * 30 )
	Variables(
		X( :weight ),
		X( :"list*30"n, Position( 1 ) ),
		Y( :height ),
		Y( :height ),
		Color( :sex )
	Elements(
		Position( 1, 1 ),
		Bar(
			X( 1 ),
			Y,
			Legend( 5 ),
	Elements(
		Position( 1, 2 ),
		Bar( X( 2 ), Y, Color( 0 ), Legend( 6 ), Summary Statistic( "Sum" ) )
lala
Level IX
Is this a mistake?
Thanks Experts!
Level XII
Thanks, I corrected it in the code.
with the original column ("list") the bottom graph will be squeezed to the left.
with "list*30" the bars will fill the whole graph.
lala
Level IX
d0 = Current Data Table();
dt = d0 << Subset( Output Table( "test" ), Selected Rows( 1 ), selected columns( 0 ) );
d2 = dt << Summary( Group( age, height ), Sum( weight ), Freq( 0 ), Weight( 0 ), Link to original data table( 0 ), Output Table( "tem" ) );
ma = Max( d2[0, 4] );Close( d2, nosave );
d2 = dt << Summary( Group( age ), Freq( 0 ), Weight( 0 ), Link to original data table( 0 ), Output Table( "tem" ) );Column( d2, 2 ) << set name( "row" );
ca = "ratio";New Column( ca );Column( ca ) << Formula( Round( row / mi, 2 ) );d2 << run formulas;Column( ca ) << deleteFormula;
dt << Update( With( d2 ), Match Columns( age = age ) );Close( d2, nosave );
Current Data Table( dt );ca = "list";New Column( ca );
Column( ca ) << Formula(If( Row() == 1 | age != Lag( age, 1 ),r = Row();1,Ceiling( (Row() - r + 1) / ratio * ma / mi )	));d0 << run formulas;Column( ca ) << deleteFormula;
