aekw0
How to correctly refer to a column that is not in the current data table?
I've tried:
dt = Data Table("Big Class");
Distribution(Continuous Distribution(Column(dt,"height")));
but it doesn't work at all.
Thanks, Anna
ih
ih
Re: How to correctly refer to a column that is not in the current data table?
You need to build the distribution on the big class table rather than the currently selected table, you can do that by sending the distribution script as a message:
dt << Distribution( Continuous Distribution( Column( :height ) ) );
ih
ih
aekw0
Super, thank you!
